An analysis of the working principle of a kg316t time-controlled switch circuit
Source: InternetPublisher:国民男神经 Keywords: Switching Circuit Updated: 2024/10/30
KG316T time control switch circuit
The circuit diagram is shown below:
1. Functions and features
This type of time control switch uses an eight-bit microprocessor chip, PCB board direct sealing, peripherals use SMD components, and the LCD screen displays time and control functions. It has the characteristics of small size, low power consumption, wide operating temperature range, and strong anti-interference ability.
2. Working principle and process
The time switch is intuitive and convenient to set, and you can choose manual on/off or automatic control. In automatic mode, you can set Monday, Wednesday, Friday, Tuesday, Thursday, Saturday or weekdays, weekends and other time periods for cyclic operation.
The daily on/off time can also be set separately, which can be accurate to the minute, and the number of on/off times set per day can reach 10 times. The maximum load current that can be controlled for resistive loads is 25A, and some models can control two or three different loads separately.
The model of the LCD clock control module is TOONE-10.2, with a timing error of <±0.5 seconds/day. The power consumption is less than 5W. The control switch has a 1.5V rechargeable battery and a corresponding charging circuit inside. Even if the power is off, the timing will not be affected, and the set control program will not be lost.
- Peripheral circuit of automotive motor controller power supply chip
- DC motor drive circuit composed of L293D
- Working principle of one Xipu STR soft starter controlling two motors
- Methods for Eliminating Noise of Brushed DC Motors
- Design and production of radio remote control fan stepless speed regulator
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of voice control circuit
- Electric vehicle battery charging protection circuit
- Design and production of no-load automatic power-off device for household power supply
- An experimental model of an infrared radio alarm
- Sound remote control switch circuit
- Touch switch power circuit
- Automatic periodic switching circuit 4
- Contactless proximity switch circuit 2
- Thyristor AC switch circuit one a
- One of the lighting sound and light control switch circuits
- Lighting sound-activated switch circuit using thyristors Part 2
- Touch lighting switch circuit four
- Ultrasonic remote control light switch circuit
- Sub-ultrasonic remote control light switch circuit (1)
