Introducing the CD4013 washing machine timer circuit diagram
Source: InternetPublisher:他们逼我做卧底 Keywords: Washing machine circuit diagram timer circuit CD4013 Updated: 2021/06/27
In semi-automatic washing machines, the wash timer and motor commutator both use mechanical time switches, which will become damaged after a period of use. This washing machine electronic timer can replace the above-mentioned mechanical time switch. The electronic timer circuit of the washing machine is shown in the figure. IC1, VT1, K1, etc. form an electronic timing switch to control the washing timing time of the washing machine. The monostable circuit composed of IC1 (1/2 double D flip-flop CD4013 ), resistor R4 and capacitor C3 determines the monostable time, which is the timing time. The timing of the circuit in this example is 40 minutes. The switch SA is made by modifying the timing switch of the original washing machine . When the knife position is moved to terminal 1, the timing starts. At this time, the Q terminal of IC1 is high level, VT1 is turned on, and K1 is closed. Contact K1 is closed, supplying power to the motor control circuit, and the motor rotates. During the timing time, SA can be dialed to terminal 2 at any time to reset the circuit and stop timing.
- What is a photocoupler and how to select and use one?
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- FPGA Features and Architecture
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Transfer characteristics of BJT, how to apply Shockley equation?
- Why use PWM? What are its advantages?
- Make a flameless electronic candle using simple electronics and LEDs
- An example of proportional integral circuit diagram
- Circuit diagram of a differential amplifier circuit
- Small capacitance and long duration timer circuit diagram
- Use CD4013 to make a single-button touch light switch
- Time sharing timer circuit
- Lighting timer circuit
- Timer circuit using Darlington circuit
- exposure timer circuit
- 555 photo exposure timer circuit
- Pocket electronic timer circuit diagram
- Precision timer circuit diagram
- Low power timer circuit diagram
