Simple level conversion circuit diagram
Source: InternetPublisher:3228 Keywords: Circuit diagram level conversion circuit transistor logic level Updated: 2020/12/19
The level shifting circuit includes fast switching transistors Q1 and Q2. The user selects the level shift high and shift low, which are the DC bias voltages connected to the emitters of the transistors to match the desired output high logic levels low logic levels . C1, R1, D1, C2, R2 and D2 keep the base voltage of Q1 and Q2 close to the emitter voltage.
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- How to read resistor color codes? Resistor color codes illustrated
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- Causes of PCB deformation How to prevent circuit board bending and warping
- Make a flameless electronic candle using simple electronics and LEDs
- How to build a triangle wave generator using an op amp and discrete components
- Summary of knowledge points of multiplexer
- LED Night Light
- Crystal controlled local oscillator circuit diagram
- A single-section transistor performance test circuit
- Mixer built with analog multipliers
- water saving circuit
- Transistor meter circuit d
- The process and phase relationship of the driving signal from t1 to t2 (120° to 240°)
- transistor audio signal amplifier
- transistor voltage amplifier ac current
- Counting circuit composed of transistors
