Typical channel monitoring circuit diagram
Source: InternetPublisher:拿铁三分糖 Keywords: Circuit diagram monitoring circuit DAC ADC Updated: 2021/11/18
In multi-channel DAC systems, being able to monitor all outputs from a single point is very beneficial for troubleshooting and diagnostic analysis. The circuit described in this article utilizes a single-channel SAR type ADC to implement output channel monitoring of a multi-channel DAC.
The circuit diagram shown below utilizes the internal multiplexer of the 40-channel, 14-bit DAC AD5380 to allow all 40 output channels to be routed individually to a single output (MON_OUT) pin and then through an external ADC (AD7476) Monitor. This approach utilizes far less circuitry than would be required to monitor each channel individually.
![Typical channel monitoring circuit diagram](http://www.eeworld.com.cn/circuit/upload/c18729ab24f23f8de090d8a63a673754/18cf7df0f854670ac3fd2cb5303c8fd4.jpg)
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Step-down power supply for driving relays
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED rechargeable flashlight circuit diagram
- Dual forward converter schematic diagram
- Power supply circuit that can reduce LM317 ripple
- Design of electric vehicle charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- Homemade home inverter circuit diagram
- Design of adjustable DC stabilized power supply circuit module
- DC 12V to AC 100V inverter power supply circuit design
- Industrial product promotion and shopping guide DC power supply circuit
- Typical Reference Voltage and Power Supply Circuits
- EPSON PHOTO 830U printer power circuit
- Commonly used power circuits in printers
- Rectifier circuit without diodes
- Tube amplifier TDA1543 DAC-2 circuit diagram
- Tube amplifier TDA1541NOS DAC tube version power supply circuit diagram
- Tube amplifier DIR1703+PCM1738 DAC circuit diagram
