Z37 radial drilling machine control circuit
Source: InternetPublisher:王达业 Keywords: Control circuit BSP spindle switch Updated: 2021/04/04
It is mainly composed of three parts: spindle
rotation, rocker arm lifting and column elasticity
. The power supply of the electrical control box
is powered and grounded by four bus rings HTH installed in the rocker lifting L structure box
The actions of the electrical components in the machine tool control circuit are all completed by the cross switch
SAi.
Only one pair of the four pairs of cross switches can be connected at any time, so that the rocker arm and the spindle motor cannot operate at the same time. The speed change and forward and reverse operation of
the spindle
are realized through the mechanical structure. Its circuit control principle is similar to that of the inching circuit. The
only difference is that the button is replaced by the contact of the cross switch . The electrical components
of the control circuit are shown in Table 5-3.
- Hot wire spark plug control circuit
- Smart car control system circuit design strategy
- morning bird
- Catillac luggage compartment opening circuit diagram
- Smoke alarm circuit (1)
- One of the cooling fan automatic control circuits
- Nine-digit key code lock circuit
- Commonly used oil pump motor control circuits for presses
- stapler main circuit
- Cadillac seat memory circuit diagram
- Ultrasonic blind pathfinder circuit
- Homemade disinfectant circuit
- Fish pond oxygenation reminder circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Mixer built with analog multipliers
- Diode balanced amplitude modulation circuit
- common emitter amplifier circuit
- Three primary color display circuit
- Power phase sequence display circuit
- Home appliance repair signal generator circuit
