Subwoofer low pass filter circuit diagram explanation
Source: InternetPublisher:桂花蒸 Keywords: Low pass filter subwoofer Updated: 2024/07/12
The sound spectrum is in the range of 20Hz to 20000Hz. It is difficult for a single speaker to reproduce the sound of the entire frequency range well, so the HIFI audio system will take out the bass part of the sound level and amplify it separately to send it to the independent bass speaker for sound reproduction, so that the shocking effect of the bass will be more prominent. The following will be such a low-pass filter, which is used to separate the bass part from the two-channel signal of ordinary audio equipment and send it to the bass amplifier.
Low pass filter circuit diagram
Component
R1 = 39 kOhm
R2 = 39 kOhm
R3 = 47 kOhm
R4 = 10 ohms
R5 = 22 kOhm
R6 = 4,7 kOhm
R7 = 22 kOhm
R8 = 4,7 kOhm
R9 = 10 ohms
R10 = 220 ohms
C1 = 39 pF
C2 = 0.1 uF
C3 = 0.1 uF
C4 = 0.2 uF
C5 = 0.4 uF
C6 = 0.1 uF
C7 = 0.1 uF
IC1 = TL064
Printed Circuit Board
Component location
- Divider Circuit
- A4 switching power supply is absolutely available: Hitachi A3P-B2 power supply (A4)
- Single-phase full-wave rectification π-type filter circuit
- Dual video amplifier circuit
- Low pass filter (integrator) circuit
- High-precision instrument amplifier circuit
- Two-stage video amplifier circuit
- Broadband distributed amplifier circuit
- Active dual secondary bandpass filter circuit
- Frequency selection voice control circuit
- Crystal controlled local oscillator circuit diagram
- Transistor circuit diagram explanation
- Direct coupling amplifier circuit circuit diagram
- Differential circuit diagram
- NE5532 operational amplifier circuit diagram
- base amplitude modulation circuit
- Isolation transformer and low-pass filter wiring b
- audio low pass filter
- Homemade subwoofer playback system 01
- Fourth-order low-pass filter circuit without capacitive components
