Fire pump (one in use and one in standby) soft start control circuit c
Source: InternetPublisher:司马缸砸光 Keywords: control circuit soft start start control Updated: 2021/09/25
The soft start control circuit of the fire pump (one in use and one in standby) using FSR1000X soft starter is shown in Figure 5-26. When the transfer
switch 1SA is placed in the automatic position, one of the two fire pumps is running and the other is in standby. The two pumps are standby for each other
. After an operation failure, the standby pump is automatically put into operation immediately. When 1SA is placed in the manual position, both pumps can be operated manually and independently. The time relay
(KT) delay setting value is greater than the soft start time of a single unit.
In the figure, 1 and 2 are bypass relay terminals ; 3 and 4 are fault output terminals; 7 is instantaneous stop input terminal; 8 is soft stop input
terminal; 9 is soft start input terminal; 10 is common contact input terminal (COM ); Il is the ground terminal (PE);
12 and 13 are the control power input terminals .
- Production of two-color music lantern
- UCC587x-Q1 power-on false alarm mechanism and initialization precautions
- Micro infrared receiver module PIC-12043S circuit diagram
- Music calendar using SMC6S37
- GW-0520CH-PS switching power supply circuit diagram
- Catillac luggage compartment closing circuit diagram
- JS13 type transistor time relay circuit
- Toy police car circuit
- Electronic ventriloquist circuit
- Cadillac reversing light circuit diagram
- time control circuit
- Stapler control circuit
- sound control circuit
- CPU input and output and memory control circuit
- Digital current loop control circuit
- Neon light control circuit
- Automatic sprinkler irrigation control circuit
- Electric heater temperature detection control circuit
- Fire pump (one in use and one in standby) soft start control circuit a
- Auto-decompression starting control circuit
