long time timing circuit
Source: InternetPublisher:失踪的猫 Keywords: Timing circuit BSP components Updated: 2021/07/16
(1) Circuit Principle: Figure 3-21 shows a long-term timing circuit . in the circuit. Al adopts FET input type transportation and storage TL082. The voltage
at the non-inverting input terminal is half of the saturation voltage (about 12V), while the voltage at the inverting input terminal is fixed at about +o due to the conduction of VD1. 6V.
If the trigger terminal inputs a negative pulse above 6V, the Al output will show negative saturation, and the voltage at the non-inverting input terminal will be approximately -6V. The capacitor Ci is reversely charged through the resistor
Ri. If the charging voltage exceeds -6V. Al J out reaches positive saturation, and the 10-timing period ends. Charging time T=R,Gln
(Rz+R3) /R3, when Rz= Ra. TO. 7R1G.
(2) Component parameter selection The selection of components is shown in Figure 3-21, and there are no special requirements.
- Design of an autonomous plant watering system using ATtiny85
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to build a simple tachometer using an infrared reflectance sensor
- Manual automatic air compressor control circuit
- Motor automatic cycle control circuit
- Design and analysis of a four-bit remote control component capable of remote reset
- A novel and practical power line anti-theft and cutting alarm circuit
- Ultra-short wave item left behind reminder alarm
- Vibration anti-theft alarm circuit
- Simple disconnection burglar alarm
- Excellent performance household inverter power supply circuit
- Analysis of rectifier circuit types and principles
- Electronic thermometer circuit
- Smoking Cessation Circuit
- soil content measurement circuit
- Rural fish farming control circuit
- Rural vegetable greenhouse lighting circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Wireless microphone circuit
- Three primary color display circuit
