555 power-on delay output high level circuit
Source: InternetPublisher:toothache Keywords: BSP Updated: 2021/08/12
Introduction to circuit principle The circuit is shown in Figure 3-1. When the power
is turned on, capacitor c1 has no time to charge. The ② and ⑥ pins of 555
are at high level, and the ③ pin outputs low level. As the capacitor Cl charges
, the potential of pins ② and ⑥ of 555 begins to decrease. When the potential of pin ② is lower than
Vcc, the circuit flips, and the output terminal U{. changes from low level to high level
, and remains so. c boot delay time·Av hand 1. IRC. The diode VD is set up to discharge the capacitor
after the power is turned off . This
circuit is generally used to control the delayed turn-on of the power circuit.
(2) Component parameter selection The selection of components
is shown in Figure 3-1, subject to special requirements.
(3) The 555 power-on delay output high-level circuit is shown in Figure 3-1.
- Signal diode arrays/configurations, freewheeling diode operation
- Which one is better, NPN or PNP transistor?
- An article explains the working principle of the Wheatstone bridge
- In-depth analysis of energy losses in oscillation frequencies
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Datasheet/Pinout/Technical Specifications of LMC555
- Important things to know about PCB routing and how to design the right routing for your PCB
- An example of proportional integral circuit diagram
- Motor overcurrent protection circuit
- Analysis of rectifier circuit types and principles
- Electronic thermometer circuit
- stuttering correction circuit
- Electronic anti-asthma circuit
- Farmland irrigation automatic control circuit b
- Junction field effect transistor mixer circuit
- Double detuned loop frequency discriminator circuit
- Capacitive feedback oscillator circuit
- Various signal generator circuits
