Control geography capable of issuing start and stop signals
Source: InternetPublisher:司马缸砸光 Keywords: BSP electric motor Updated: 2020/12/22
For some large-scale mechanical equipment, the moving parts driven by the motor have a large range of movement, so a starting signal needs to be sent before starting, and
the motor will be started after a period of time to inform the staff and maintenance
personnel stay away from the equipment, as shown in Figure 4-28 The circuit shown enables
the function of automatically sending out a start signal.
To start the pair, press the button SB2, the relay KA will be energized
and self-locking, its moving and closing contacts will be closed, and both the bell and light will send out starting
signals . At this time, the time relay KT will also be energized at the same time. After
Imin (the time can be Adjust the connection as needed), the KT moving closing contact delays
closing, the contactor KM coil is energized, the KM main contact closes, the moving closing
auxiliary contact self-locks, the motor M starts to run, and at the same time due to
the pull-in of KM, its moving The broken contacts disconnected KA and KT, and the bell
and light bulb lost power and stopped working.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- The meaning and importance of circuit protection, common types of circuit protection
- Use your smartphone to turn on/off the power in your home
- A small improvement to the temperature and water level indicator alarm
- Motor control circuit for starting and running without phase loss
- IGBT modules block overcurrent by controlling the gate
- Hydraulic control circuit design and analysis
- An experimental model of an infrared radio alarm
- Precious home appliance anti-theft alarm
- Password type motorcycle anti-theft device
- Set timing circuit when power is on
- High-efficiency speaker circuit for rural stage
- Fish farming thermostatic control circuit
- Agricultural spraying and insecticide control circuit
- Soil water shortage prompt circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Diode balanced amplitude modulation circuit
- Color display circuit
- Guest arrival signal recognition circuit
- Digital stopwatch display circuit
