Electric curtain circuit b Household appliance circuit
Source: InternetPublisher:toothache Keywords: Household appliances electric curtains electrical circuits switches Updated: 2020/07/13
This circuit only uses two limit switches ST1 and ST2. A DC toy motor M. A double pole double
throw switch QS and a set of 6V dry batteries.
Move the double-pole double-throw switch to d and b, the motor M will rotate forward, and the transmission rope will drive the curtain and the impact block to move in a certain direction. When the impact pressure block
touches the limit switch ST1, the circuit is disconnected and the work stops. When the double-pole double-throw switch is moved to a and c, the motor M reverses and the curtain
moves in the opposite direction. When the impact pressure block hits the limit switch ST2, the circuit is disconnected and the work stops.
2) The circuit is shown in Figure 1-9b. Using AC power supply, the circuit is simpler. The micro switches sl and S2 only require a pair of normally closed contacts, and
the switch S3 used to control the opening and closing of the curtains is a 2X2 toggle switch . Figure 1-9b shows the curtain in the stopped state after being closed. Due to the use of half-wave rectification
, the DC voltage output is lower than 6V. However, most toy motors on the market can operate normally with only 3V voltage, so it will not affect their use.
- Feiyue WP-600 computerized microwave oven computer control diagram
- Non-contact refrigerator power-off protector circuit
- Xerox BCD-238 three-door refrigerator circuit
- Thundercloud distance detector circuit
- Broadband high frequency amplifier
- Debei brand SC45STIV, BC-347 refrigerator circuit
- Universal inverter deceleration braking circuit
- Chennuxi brand BCD-180 refrigerator circuit
- Printed circuit diagram of power converter
- Transformer AC contactor DC operation circuit a
- Causes of inductor whistling in DC/DC circuits and related solutions
- Complementary voltage switching class D power amplifier circuit
- Three primary color display circuit
- Using 74LS244 to expand 24-channel input interface circuit
- Connection circuit of thumbwheel switch ICM7217
- Typical relaxation oscillator and output voltage triangle wave
- humidification circuit
- Temperature detection control circuit of electric kettle
- Electric fan circuit household appliance circuit
- Household appliance power timer circuit
