Transistor controlled rectifier circuit d
Source: InternetPublisher:清宁时光 Keywords: transistor rectifier circuit controlled rectification thyristor Updated: 2021/11/21
Without affecting the accuracy of engineering calculations, when analyzing the rectifier circuit below, both the thyristor and the rectifier diode are regarded as ideal
components , that is, the forward voltage drop during turn-on and the leakage current during turn-off are ignored. ·And the turn-on and turn-off are instantaneous.
The thyristor controllable rectifier circuit is shown in Figures a-d. Their working principles are
similar to ordinary diode non-controllable rectification circuits
. The difference is that the thyristor must have a forward voltage between the anode and the cathode, and a certain trigger pulse between the gate and the cathode. signal
to conduct the work. Each thyristor requires a trigger circuit. The load is resistive and inductive.
- 7805 adjustable voltage regulator circuit diagram, 7805 circuit analysis
- LM350 adjustable voltage regulated power supply circuit diagram
- What does power ripple mean? How big is the DDR power ripple requirement?
- What effect does the copper coating on the bottom of the inductor have on the power supply?
- Introduction and principle analysis of switching regulated power supply
- Step-down power supply for driving relays
- What kind of circuit is a voltage regulator circuit?
- Basic connection circuit of signal and power supply composed of ISOll3
- Op amp power supply decoupling bypass measures
- Simple and practical LED lamp driving circuit
- Three-phase controllable rectifier circuit b
- Transistor controlled rectifier circuit a
- Even-numbered voltage doubler full-wave rectifier circuit a
- Full-wave capacitor step-down rectifier circuit b
- Full-wave capacitor step-down rectifier circuit a
- Half-wave capacitor step-down rectifier circuit a
- Three-phase multi-switch Buck type rectifier circuit
- Resistor-capacitor step-down rectifier circuit
- Crystal diode single-phase half-wave resistive load rectifier circuit
- One of the rectifier circuit diagrams that outputs two voltages
