Simple transistor inverter circuit diagram
Source: InternetPublisher:赔钱虎 Keywords: transistor integrated power supply inverter Updated: 2020/04/21
In remote villages, there are often power outages, and some universities will automatically turn off the lights at a certain time, but that doesn't matter. With it, these can be solved.
![Simple transistor inverter circuit diagram](http://www.eeworld.com.cn/circuit/upload/ce7f16b63456d4e365a44caa6050ddfe/9a13ec265ea9423e8ea1062868b7393c.gif)
This is a very easy-to-make inverter that can change the 12V power supply voltage into 220V mains power. The circuit is driven by a multivibrator composed of BG2 and BG3, and is driven by BG1 and BG2 to control the work of BG6 and BG7.
The oscillation circuit is powered by the regulated power supply of BG5 and DW groups, which can make the output frequency more stable.
During production, the transformer can be selected from the common mains transformer with dual 12V output. The capacity of the 12V battery can be selected as needed.
- Analysis of the working principle of switching regulator
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Benefits of Wide Bandgap Technology for Power Converters
- 220V Remote Load Monitor
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Switching power supply circuit composition and function introduction of each part
- Power supply circuit that can reduce LM317 ripple
- 0.7~24V continuously adjustable current limiting power supply
- Homemade home inverter circuit diagram
- Tire flat alarm circuit
- JSJ type transistor time relay circuit
- Blocking monitoring circuit
- Transistor withstand voltage measuring instrument circuit d
- Transistor withstand voltage measuring instrument circuit a
- Internal structure of DTL inverter circuit
- Alarm circuit for induction cooker
- Buffer amplifier with small back radiation
- transistor voltage amplifier
- A single-section transistor performance test circuit
