Woodworking machine tool circuit a
Source: InternetPublisher:张三叔 Keywords: Machine tool circuit stepper motor drive circuit oscillation Updated: 2020/05/09
General stepper motors require leap phase or multi-phase pulse power supply as the driving power supply. The road to invitation is more complicated and the cost is higher. This production
uses a new approach, using the impedance of the two windings of the motor to achieve positive feedback to generate oscillation , achieving a separately excited drive. The circuit only uses 7 parts.
Figure 2-25a is a single-ended drive circuit , and Figure 2-25b is a push-pull drive circuit . In order to obtain the required torque j stepper motor, type 23LM-0304-14 is selected
, its rated voltage is 5. 1V. The rated current is 1.OA and the step size is L 8.
- Tutorial on making a handheld Geiger counter
- Share a fire sensor solution using MLX90640
- The production principle of high voltage self-defense flashlight and electric stick
- A novel resonance demonstration device
- How to design a mask disinfection device using infrared temperature sensors
- How to create image processing solutions using HLS capabilities
- Input and output polarity reversal circuit composed of MAX660
- A detection circuit with keen hearing
- Driving Large TFT-LCD Displays with Space-Saving Triple-Output Regulator
- Discrete component laser driver circuit
- Variable frequency motor drive circuit
- Multivibrator infrared transmitter circuit
- 8-bit digital LCD display driver circuit
- Light emitting diode (LED) display driver circuit
- Tongzhou CDVB2200 set-top box digital display and drive circuit
- The oscillation process of a multivibrator a
- humidification circuit
- UC3717 stepper motor control circuit
- MTD1120F stepper motor control circuit
- Oscillation experimental circuit
