Tongzhou CDVB2200 set-top box digital display and drive circuit
Source: InternetPublisher:刘德华河北分华 Keywords: drive circuit digital display shift Updated: 2020/04/22
Shown is the digital display and drive circuit of Tongzhou CD VB2200 set-top box. The display circuit consists of a 4-bit 7-segment digital tube 74HC595
and a drive circuit . The CPU inputs the programmed shift clock, latch signal and channel number data from the GP10 port to the 8-bit serial
input or vertical input shift memory. The 74HC595 completes the conversion work and drives the digital display according to the The entered data displays the corresponding
channel.
- One-digit display
- Digital level display (CD40147, CD4511)
- IR2153 emergency fluorescent lamp circuit diagram
- Driving circuit for driving light-emitting diodes by IR53HD420
- Corridor automatic light-off device
- Simple electronic doorbell circuit
- Two-way electronic music doorbell circuit
- Electronic rapid starter for fluorescent lamps
- Incandescent lamp dimming circuit using thyristor part 4a
- Reverse polarity drive circuit
- Variable frequency motor drive circuit
- Hard drive motor drive circuit
- Fluorescent digital display tube drive circuit
- LED display drive circuit a
- SANYO 1100W vacuum cleaner motor drive circuit
- Motor drive circuit for stable speed control using negative feedback method
- Light controlled motor drive circuit
- Recorder graphic equalizer drive circuit
- DC motor drive circuit
- Simple three-phase brushless stepper motor drive circuit
