Electric hoist circuit
Source: InternetPublisher:公子李 Keywords: Electric motor BSP Updated: 2021/03/20
An electric hoist is a small lifting machine, mostly used for lifting equipment. It consists of two parts: a hook and a mobile crane. The lifting
and traveling of the hook are driven by an electric motor . The lifting motor drives the drum to rotate, thereby driving the hook to rise or fall. The traveling motor drives
the lifting mechanism to move horizontally on the I-beam, so that the brick-carrying crane moves forward or backward. Its appearance and control circuit are shown in Figure 2-16a and b.
The main circuit uses circuit breaker QF for short-circuit protection. Contactors KMl and KM2 control the lifting electric gourd Ml, and KM3 and KM4 control the traveling motor
M2 to run forward and reverse. They all rely on changing the phase sequence applied to the three-phase power supply of the motor
- What is the LiFePO4 discharge curve? Advantages and applications of LiFePO4 discharge curve
- How to use Tesseract for optical character recognition on Raspberry Pi
- Make a draft beer machine using Windows 10 UWP
- How to implement semaphores and mutexes in FreeRTOS using Arduino
- Building a Dehumidifier for a 3D Printing Dry Box
- DIY a simple weather station
- Production of electric water bottle energy saver
- How to design a mask disinfection device using infrared temperature sensors
- Driving Large TFT-LCD Displays with Space-Saving Triple-Output Regulator
- Laser constant power control circuit
- Set timing circuit when power is on
- Analysis of rectifier circuit types and principles
- Electronic thermometer circuit
- Smoking Cessation Circuit
- Wien bridge oscillator circuit
- Crabo oscillator circuit
- OTL low frequency power amplifier circuit
- Fault signal trip circuit
- Various signal generator circuits
- Sine wave signal generator circuit
