Y3150 gear hobbing machine control circuit
Source: InternetPublisher:toothache Keywords: control circuit BSP electric motor mobile Updated: 2021/07/16
Commonly used in general production workshops and machine repair workshops, the Y3150 type gear hobbing machine is used: the machine is mainly based on the pre-mechanical mechanism, M1 is the tool holder motor
, for forward and reverse jogging and one-way starting operation; MZ is the cooling pump motor , the control line is in the middle of the control line from the special switch dance to the thin mushroom stop
It has forward and reverse limit switches, and is equipped with low-voltage lighting and indicator light circuits. Figure 2-13a and b are the appearance and control circuit of
the Y3150 gear hobbing machine . When the button SB1 is pressed during operation, the contactor KM1 is electrically closed, and
the main contact is closed, causing the motor M1 to drive the tool holder to move downward . When it reaches the end point, it collides with the travel switch SQ2 and stops running. If
the tool holder is required to move upward, press the start button SB4 to reverse the movement of the motor upward . If you need the main motor of the knife to move downward, press button
SB3 to achieve the inching operation. - r. . √,
- Factors affecting the life of LiFePO4 batteries, how to extend the life of LiFePO4 batteries
- How to Make a Bass Boost Speaker Box
- Design of a drone wildlife counting system using FOMO object detection algorithm
- Analysis of the circuit principle of ZX5-630 welding machine
- Infrared detection type electronic rodent killer circuit
- Working Principle and Production of TV Scanning Demonstrator
- Ultrasonic dog chaser made by NE555
- Production of electric water bottle energy saver
- DIY Solar Detector
- Laser constant power control circuit
- Egg warming circuit
- Rural fish farming control circuit
- Straw returning to field crusher circuit
- Agricultural spraying and insecticide control circuit
- Biogas concentration detection line
- Farmland drainage automatic control circuit
- Diode Balanced Mixer Circuit
- Inductive feedback oscillator circuit
- Differential Amplifier Circuit
- Home appliance repair signal generator circuit
