6-channel audio mixer
Source: InternetPublisher:yO9n3 Keywords: audio mixer Updated: 2026/01/16
The mixer circuit below has 3 line inputs and 3 microphone inputs. The microphone inputs are suitable for low-impedance dynamic microphones (200-1000 ohms). ECM or condenser microphones can also be used, but they must be biased through a series resistor.
As with any mixer circuit, slight losses are always introduced. This is overcome by a final summing amplifier with a gain of 2x or 6dB. The input line levels should be approximately 200 mV RMS. The microphone input is amplified by approximately 100x or 40dB, resulting in a total mixer gain of 46dB. The microphone input is designed to output approximately 2 mV RMS at 1 meter. Most microphones meet this standard. The choice of operational amplifier is not critical in this circuit. Therefore, bipolar, FET-input, or MOS operational amplifiers can be used; for example, 741, LF351, TL061, TL071, CA3140, etc.
- 7 Watt Class A Audio Amplifier
- 18-watt audio amplifier
- High-fidelity headphone amplifier
- High-performance stereo audio amplifier using LM3886
- 100-watt power amplifier
- Miniature voice recording and playback circuit
- A simple tone generator circuit
- TA7233 audio power amplifier circuit diagram
- LM4819 audio power amplifier circuit diagram
- Make a pocket amplifier with 8550 and 8050
- LA4461N audio IC circuit
- TDA2030 audio power amplifier circuit diagram
- Voice controlled bird circuit
- Transistor Audio Mixer Circuit Diagram
- 2-tube FM microphone with 3V power supply
- Simulating bird call circuit schematic diagram
- Several good field effect transistor power amplifier circuit diagrams
- Squelch Tuned Audio Switching/Mixing Circuit Diagram
- transistor audio mixer
- High quality melody circuit
京公网安备 11010802033920号
