LM386 0.325 Watt Audio Amplifier
Source: InternetPublisher:bH3tk1WmIK Keywords: Audio amplifier Updated: 2025/12/12
The LM386 is a power amplifier designed for low-voltage consumer applications. The internal gain is set to 20 to keep the number of external components small, but adding an external resistor and capacitor between pins 1 and 8 can increase the gain to any value between 20 and 200.
The input is ground-referenced, while the output is automatically biased to half the supply voltage. With a quiescent power consumption of only 24 milliwatts when operating from a 6-volt supply, the LM386 is well-suited for battery power.
characteristic
• Battery powered
• Minimal external components
• Wide power supply voltage range: 4V–12V or 5V–18V
• Low quiescent current consumption: 4mA
• Voltage gain from 20 to 200
• Ground reference input
• Self-centering output static voltage
• Low distortion: 0.2% (AV = 20, VS = 6V, RL = 8W, PO = 125mW, f = 1kHz)
• Available in an 8-pin MSOP package
- 2-watt mini box amplifier
- LM3875 power amplifier
- Class A headphone amplifier
- 50W LM3886 Power Amplifier
- Hybrid headphone amplifier
- High-fidelity headphone amplifier
- High-performance stereo audio amplifier using LM3886
- 30W MOSFET audio amplifier
- Single power supply complementary symmetrical circuit
- Make a pocket amplifier with 8550 and 8050
- Low power audio amplifier MC34119-04
- Practical voice-controlled music lantern (1)
- 8W audio amplifier integrated circuit
- Output uses DC coupled 15 to 60W audio amplifier circuit
- 12W low noise audio amplifier circuit with boost transistor
- TDA2003 10W car radio audio amplifier
- Audio amplifier circuit using high gain field effect transistors
- 35W audio amplifier circuit
- Yakong 4W audio amplifier circuit
- Audio amplifier circuit using LM386
京公网安备 11010802033920号
