Simple RF Power Meter
Source: InternetPublisher:nTiq9GUZt Keywords: RF power meter Updated: 2026/03/03
Here's a simple setup that allows them to measure the output power of their transmitter. All they need is a good multimeter with a sensitivity of 20k ohms/4 watts, which is sufficient for low-power transmitters. Many beginners have to overcome numerous problems before they can start transmitting when they first try using a QRP transmitter. A common complaint is that everything works fine, but no signal is transmitted.
The 8k resistor should be placed close to the transmitter's output terminals. Turn on the transmitter in CW mode and measure the DC voltage with a multimeter. If the voltage is V, then the output power is given by the formula Power = V^2/50.
- Cell phone detector
- Digital power meter
- Digital voltmeter
- Working Principle and Production of TV Scanning Demonstrator
- Making a simple field strength meter
- Circuit for measuring 500VDV DC motor current composed of ISO102 and OPA27
- Test circuit composed of TDA6106Q with feedback factor 1/116
- Analog capacitance measuring instrument composed of CD4013
- Wideband Strain Gauge Signal Conditioner with Boosted Excitation Voltage
- Input bypass circuit with linearization (XTR112/XTR114)
- Overcurrent detection circuit
- Long-distance ringtone detection circuit using photoelectric coupler
- A5349 type AC smoke detection circuit - block diagram
- Underwater acoustic sensor detection circuit
- Light detection circuit with output filter to reduce noise
- Differential light detection circuit
- RMS sensor detection circuit
- ADM690~ADM695 constitute a detection circuit (1)
- Optical fiber vibration measurement detection circuit
- Contact combustion type CO detection circuit
京公网安备 11010802033920号
