USB LED dimmer
Source: InternetPublisher:zeNNH4 Keywords: USB LED dimmer Updated: 2026/03/27
USB LED Gradient
A USB-LED gradient is a device that controls multiple LEDs via USB. I built it to display my internet connection status, video recorder (VDR) recording status, and low disk space warnings. You can imagine countless application scenarios.
LEDs are controlled using pulse width modulation (PWM). This allows them to not only be turned on or off, but also their brightness to be controlled. The device contains many "waveforms" that can be displayed via LEDs. Thus, an LED can display a sine wave or a triangle wave without interacting with the control host. Each LED can be controlled independently; each can display its own waveform.
You can assign three different waveforms to each LED. The first two (0 and 1) are "permanent" waveforms. They are displayed alternately until a different waveform is needed. The third waveform (2) is displayed only once; afterwards, the device will switch back to the alternation of the first two waveforms.
They are displayed alternately until a different waveform is needed. The third waveform (2) is displayed only once, after which the device will switch back to the alternation of the first two waveforms.
A waveform is described by three parameters: the waveform, the duration of a waveform repetition, and the number of repetitions before switching to the next waveform.
This version supports four LEDs. It's easy to change the number from one to eight. I haven't tested more than four, but I can imagine the controller load might be too high for reliable USB communication.
The distribution consists of three parts: the firmware for the ATmega8 microcontroller, a command-line client that can run under Linux, and the circuitry needed to build the device.
This project is based on Objective Development's PowerSwitch sample application. Similarly, it uses Objective Development's pure firmware USB driver for Atmel's AVR microcontroller.
Objective Development's USB driver is a pure firmware implementation of the USB 1.1 standard (low-speed devices) on inexpensive Atmel AVR series single-chip microcomputers, such as the ATtiny2313 and even some small 8-pin devices. It implements the standard, enabling useful applications to be implemented. For features and limitations, see the file "firmware/usbdrv/usbdrv.h".
Build and install
circuit
The circuit contains only a few standard components. No special USB chips are involved.
The installation process is described in the documentation.
usage
Connect the device to the USB port. All LEDs should blink to indicate that the device has been initialized.
Then use the command-line client as follows:
usb-led-fader status
usb-led-fader set
usb-led-fader clear
USB LED Fader Reset
usb-led-fader show
usb-led-fader test
When using the `set` function, you can define multiple waveforms at once. You only need to provide parameters for all the waveforms. See the example below.
parameter
ledId: The ID of the LED (0-n, depending on the number of LEDs in the circuit).
waveId: The ID of the waveform (0-1: constant waveform, 2: overlay).
waveformId: The ID of the waveform (0-31: brightness, 32-37: mode). For a reference on modes, please use the show function.
periodDuration: The duration for which a waveform repeats, in seconds per 10. A value of 0 can be used to reset the waveform.
repetitionCount: The number of repetitions before switching to the next waveform. A value of 0 will allow the waveform to repeat indefinitely.
Example
Get the status of all LEDs:
This will produce output similar to the following:
LED 0 curid curvalue curpos currep nextupd
0 2 26 0 23
wave waveform length repeat duration updtime
0 38 32 1 20 45
1 0 1 1 0 1
2 0 1 1 0 1
LED 1 curid curvalue curpos currep nextupd
0 14 19 0 19
0 38 32 1 20 45
1 0 1 1 0 1
2 0 1 1 0 1
LED 2 curid curvalue curpos currep nextupd
0 31 16 0 43
0 38 32 1 20 45
1 0 1 1 0 1
2 0 1 1 0 1
LED 3 curid curvalue curpos currep nextupd
0 6 9 0 39
0 38 32 1 20 45
1 0 1 1 0 1
2 0 1 1 0 1
In this output, the values curvalue, curpos, nextupd, and updtime are for debugging purposes only. Regular users should not need to concern themselves with them. The meanings of the other values should be self-evident.
Set the first LED to a medium brightness:
The above-mentioned equipment
I know I could have welded it much better... ;-)
usb-led-fader set 0 0 15 10 1
Therefore, on LED 0, waveform 0 is set to waveform 15. It will remain for one second and repeat once before switching to the next waveform. Since we have not defined a next waveform, this waveform will remain indefinitely.
Now set a second waveform on the first LED, slightly brighter than the first:
usb-led-fader set 0 1 25 10 1
This is waveform 1 on LED 0. Waveform 25 is defined as a constant brightness level. Once the second waveform is set, it will alternate with the first waveform once per second, because both waveforms have the same duration and the same number of repetitions.
Set the third waveform on the first LED:
usb-led-fader set 0 2 36 20 5
This will set the third waveform (waveform 2) on the first LED. Waveform 36 is a good sine wave, so the LED begins to change gradually. One change cycle takes 2 seconds and is repeated 5 times. Since this is the third waveform, after the repetition, the LED returns to alternating displays of waveform 0 and waveform 1, and this waveform is discarded.
Set multiple waveforms at once:
usb-led-fader set 0 0 15 10 1 0 1 25 10 1 0 2 36 20 5
This will set all the above waveforms at once. Therefore, the first LED will first transition to a sine wave five times, and then begin to alternate between two brightness levels at a rate of one second.
Clear the first LED:
usb-led-fader clear 0
This will clear all three waveforms on the first LED.
Reset device:
USB LED Fader Reset
All LEDs will flash once to indicate that the device has been reset and the LEDs are working properly.
Display the waveform on the screen:
USB-LED-Fender Show 36
wave 36 - length 64
31: *****
30: *********
29: ***********
28: ***************
27: *****************
26: *******************
25: *******************
twenty four: *********************
twenty three: ***********************
twenty two: *************************
twenty one: *************************
20: ***************************
19: *****************************
18: *****************************
17: *******************************
16: *********************************
15: ***********************************
14: ***********************************
13: *************************************
12: ***************************************
11: ***************************************
10: *****************************************
9: *******************************************
8: *********************************************
7: *********************************************
6: ***********************************************
5: *************************************************
4: *****************************************************
3: ***********************************************************
2: ******************************************************************
1: ****************************************************************
Please remember that the width of the displayed waveform corresponds to the length of the waveform. If you are displaying a very simple waveform, such as a constant brightness level (0-31), the length is 1. Therefore, only one column will be displayed.
Test equipment:
usb-led-fader test
This function sends a series of random numbers to the device. The device returns data packets, and the client looks up the differences between the sent and received numbers.
shortcoming
As mentioned above, controlling multiple LEDs with PWM is a significant workload for a small microcontroller. The same applies to USB protocol communication. These together operations place a heavy load on the device, making communication with the device not 100% reliable. However, at least in our tests, it was over 99%.
- Flashing LED circuit
- LED pulse driver
- Four special circuits for light emitting diodes
- Homemade stroboscope
- Solar lawn LED light
- 23w energy-saving lamp ballast using UBA2025 power IC
- Making a photometer with light measuring function
- Design and production of a practical electronic counting device
- Solar battery and charging circuit
- Low illumination amplifier circuit
- Provides USB Type-C® port chip solutions for lithium battery-powered devices
- STMicroelectronics USB Type-C port protection IC technology
- Additional power circuit design for USB devices
- Charger circuit powered by USB and adapter
- Based on TNY264P5 Volt/1.5A switching power supply circuit diagram
- USB lithium battery charging circuit and PCB schematic diagram
- USB device additional power
- LED dimmer circuit
- USB signal generation circuit
- 555 timer disconnection photoelectric isolation safety protection circuit
京公网安备 11010802033920号
