Temperature control fan
Source: InternetPublisher:zWUSLmL Keywords: Temperature control Updated: 2026/03/27
With this simple circuit, you will be able to control the speed of a DC fan based on the temperature measured by a temperature sensor. It is an ideal add-on to your PC cooling fan to eliminate generated noise. At the request of some users, this simple design allows for precise speed control of a 12V DC fan motor, proportional to temperature. A negative temperature coefficient thermistor (R1) is used as the temperature sensor, driving two directly coupled complementary transistors connected in a DC feedback circuit. An optional circuit is added for remote monitoring of fan operation, allowing for some coarse speed indication via increasing LED brightness.
R5 must be set to allow the motor to start precisely at the desired temperature.
Any negative temperature coefficient thermistor with a value in the range of 6K8 to 22K can work, as long as the value of R2 is one-tenth of the thermistor value.
R6, R7, and D1 are optional: R7 must be adjusted until the LED emits a faint light just as the motor is running.
part:
R1______________15K @ 20°C Negative temperature coefficient thermistor (see note)
R2_______________1K5 1/4W resistor (see note)
R3______________1K 1/4W resistor
R4_____________270R 1/4W resistor
R5______________22K 1/2W Fine-tuning cermet or carbon film
R6_____________680R 1/4W Resistor (Optional, see note)
R7_____________470R 1/2W Fine-tuning cermet or carbon film (optional, see note)
C1_____________100µF 25V electrolytic capacitor
D1______________LED (Optional, any shape and color, see notes)
Q1____________BC547 45V 100mA NPN transistor
Q2____________BD140 80V 1.5A PNP transistor
M1____________ Fan motor 12V 700mA maximum
- Resistive switch network audio volume control
- Telephone Watchdog
- 5-30 minute timer
- Dual-channel infrared relay controller
- 100-second duration switch with touch control
- Parking Assist
- Relay temperature controller based on LM35 and TL431
- High-loudness piezoelectric alarm buzzer
- Easy to make light controlled delayed flash toy car
- Applying Color TV Delay Circuit to Reclosing
- Differential amplifier emitter negative feedback gain control circuit
- fire smoke control circuit
- Switching regulated power supply circuit
- Traffic traffic light control circuit
- Three-phase stepper motor control circuit
- Detection and control circuit of electromagnetic stove
- Photoelectric detection output control circuit
- Range hood detection control circuit
- Sprinkler control circuit using AC motor
- Wide input range non-synchronous voltage mode control circuit
京公网安备 11010802033920号
