When sound enters the human ear from different directions from the top, bottom, left, and right of the head, it will be reflected from different angles of the auricle,
resulting in different changes in delay, frequency, and amplitude. Based on this, the human brain Determine the direction of the sound. This
effect caused by the pinna is called the HRTF listening rule. When recording various programs, because the recording microphone does not have
the structure of the human ear, the recorded program does not conform to the hearing rules of the human ear, and the sound field reproduced during replay It's a flat surface.
SRS technology processes the sound signal according to HRTF rules , performs signal delay and other compensation, and finally makes the sound
signal conform to human hearing characteristics. The working principle of the SRS system is: adding and
subtracting Through calculation, the corrected signal of the sound field is extracted , and then mixed into the original left and right channels, which can
enhance the information of the center sound and surround sound, so that the listener can accurately judge the position of the sound and enhance the space. feel. The bilingual technology uses
the pinna effect of psychoacoustics to give the listener the feeling of being surrounded by an actual surround sound field, and psychologically and physiologically restores the effects
caused by actual sound sources such as direct sound, reflected sound, and reverberated sound at both ears. The sound wave state creates a natural and realistic three-dimensional
surround sound field, thus creating a strong and immersive experience. The BIM system block diagram is shown in the figure.
- How to adjust the bass and treble of CXA1005
- Simple and practical small amplifier
- Make a high-quality DAC board
- Single-ended Class A amplifier using gallstone composite tube design
- Installation of electron tube differential amplifier circuit
- Using Shuguang 350C tube to make tube amplifier
- Typical application circuit of LM4903/4905 audio power amplifier
- Volume synchronization circuit constructed with discrete components
- Improved Marantz 7-tube preamplifier circuit
- Differential input audio amplifier circuit composed of LM4904
- Bone hyperplasia treatment circuit
- Pulse therapy circuit
- Chicken supplementary light to increase egg production rate circuit
- Mixer built with analog multipliers
- Integrated synchronous detector composed of analog multiplier MC1596
- Diode balanced amplitude modulation circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage controlled power supply second-order high-pass filter circuit
- Sawtooth wave generator circuit (2)
- Sawtooth wave generator circuit (1)
