High gain amplifier composed of transistors and field effect tubes
Source: InternetPublisher:张小哥 Keywords: Amplifier transistor field effect tube gain amplifier Updated: 2021/06/18
In an ordinary transistor RC coupling amplifier, even if a relatively high collector load resistor Rc is selected,
after connecting to the subsequent stage circuit, due to the low input impedance of the latter stage circuit, high equalization cannot be obtained. Effective AC load resistance
shoes. Therefore, it is impossible to obtain a high voltage gain Kv. If a transistor and a field effect transistor are combined, this
shortcoming can be overcome and a higher voltage gain can be obtained. As shown
in Figure 8-70, VTi uses a low-noise ultra-Lu transistor , and
its ^FE>IOOO can obtain a lower voltage gain. noise and higher
input impedance. It works in a small current state, and its working c is about
40tcA, so R c1 can take a high resistance value of 300kfl. Since
VT2 is a field effect transistor , its input impedance is very high and will not reduce
the equivalent load resistance of VTi. VT3 is an emitter follower
, used to reduce the output impedance of the amplifier and improve the load
capacity. The two-stage amplifier composed of VTi and VT2
has a high open-loop voltage gain. In the circuit, Rp is a DC
negative feedback adjustment potentiometer, and RF and its 33teF
capacitor in series form an AC negative feedback. The amplifier has stable gain
and DC working status. Its total gain Kv= (RF+ RE) is E. Changing RF can adjust Kvo and Rp so that
the emitter voltage of VT3 is 10V. The amplifier is in the normal working state. The stability of the circuit is quite good, and there is no need to connect a high-frequency
compensation capacitor. Can work in the frequency range of 5 ~ 500kHz. However, its input signal should be small.
- Signal diode arrays/configurations, freewheeling diode operation
- What does a rectifier do? What is the process of rectification?
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- In-depth analysis of energy losses in oscillation frequencies
- Diode-based clipping circuit
- Share an interesting LED decoration project
- Tutorial on building a NOT gate using BJT transistors
- Summary of knowledge points of multiplexer
- Simple LED advertising light circuit
- An example of proportional integral circuit diagram
- Valuables detection circuit design
- Field effect transistor OCL power amplifier circuit
- Working principle diagram of complementary symmetrical field effect transistor
- Combination of grounded source and common emitter amplifier
- One of the field effect tube time relay circuits
- Basic amplifier circuit of field effect transistor (c)
- Pure Class A Preamplifier
- Circuit diagram of field effect transistor for output tube
- JS20 series transistor time relay all field effect tube power-on delay circuit
- Transistor-FET crystal oscillator circuit diagram
