Combination of grounded source and common emitter amplifier
Source: InternetPublisher:傻阿乐 Keywords: Ground amplifier emitter follower field effect tube Updated: 2020/06/08
Combination of grounded source and common emitter amplifier. The input impedance of the common emitter amplifier is in the range of l03fl, so it is difficult to be directly driven by a field effect transistor
. However, if a first-level emitter follower is used , it is used as the load Rtun as shown in the figure and is connected to the common emitter amplifier . Before
, it was easy to drive, as shown in the picture. This circuit adds an emitter follower stage in front of the output stage to obtain
current gain and is an example of a typical low output impedance.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- The Importance and Ideal Model of Impedance Matching
- FPGA Features and Architecture
- How to calculate the value of capacitors in parallel?
- Tutorial on building a NOT gate using BJT transistors
- What is the difference between high-side and low-side resistive current sensing
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Power supply design experience summary
- Working principle diagram of complementary symmetrical field effect transistor
- Three configuration circuits of field effect transistor b
- TT system
- field effect transistor amplifier circuit
- AP500 and its application circuit (c)
- Double button field effect tube dimmer circuit
- Circuit diagram of field effect transistor for output tube
- JS20 type transistor time relay all field effect tube power off delay circuit
- 10A output 1-5V low voltage high current converter
