Application of adjustable voltage regulator W317
Source: InternetPublisher:拿铁三分糖 Keywords: voltage regulator adjustable voltage regulator voltage regulation Updated: 2021/11/06
It is the application circuit of three-terminal integrated adjustable voltage regulator CW317. It is known from the parameter table that the maximum input voltage of tCW317
is 40V, and the output voltage adjustment range is continuously adjustable from 1.25 to 37V. Its voltage adjustment function is completed through a
fixed resistor Ri and a potentiometer RP. The resistance of the resistor Ri is 240fl, which is connected between the voltage-stabilizing output terminal vo and the adjustment
terminal ADj. The voltage at both ends is 1.25V. Due to the voltage stabilizing effect of the voltage regulator , the voltage on Ri remains unchanged
, and the current flowing through Ri is a constant current, and its value is, Rl - REF/R1; 1.25V/2400≈5mAa
- The basic principles of power supply design. What are the key components of a power supply?
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Driving circuit of switching power supply field effect tube
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Basic circuit description of adjustable voltage regulator LM317
- Constant current LED lamp driver circuit with soft start and anti-shock
- Adjustable regulated power supply with current limiting protection
- Car Audio Power Supply
- LM317T voltage regulation adjustable circuit diagram explanation
- 24V power supply pure flat display high voltage power supply circuit diagram
- Solar power circuit
- Typical Reference Voltage and Power Supply Circuits
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Industrial four-way programmable controller power circuit
- Neon light high voltage power supply circuit
- Adjustable voltage regulator block application circuit diagram
- Novel and practical stabilized voltage power supply circuit, adjustable voltage stabilizing circuit diagram
- Adjustable voltage regulator circuit with low output voltage
