M65839 application circuit
Source: InternetPublisher:失踪的猫 Keywords: application circuit potentiometer Updated: 2021/04/30
It is the application circuit of M65839SP . The gain and bandwidth of microphone 1 and microphone 2 are adjusted by the
external resistor-capacitance components connected to pins 3 and 4 and pins s and 9 . The gain of this circuit is set to 67dB, the low-end turning frequency Si=210 and the high-end turning
frequency fch=5.5Ⅺ7. R1 and R2 can reduce the noise when the microphone is plugged in and out. C2 and C7 are ALC time constant setting capacitors
. RPl, RP' and RP3 are the volume and reverberation volume adjustment potentiometers of microphone 1 and microphone 2 respectively . When the level of pins 34, 35 and 36 increases,
the volume increases, and vice versa. Three volume controls are also available. Clock pulse control, then
pin 30 should be set to high level . The basis' is the feedback control potentiometer, if self-excitation occurs during use. A 10kfl resistor c
R.Ps and RP6 can be connected to the left and right channel volume control potentiometers .
- Homemade high quality preamplifier tone circuit
- Sugon New Tube 2A3C Single-ended Tube Amplifier
- Installing a tube preamplifier in the power amplifier
- DIY a stylish Bluetooth speaker
- Amplifier circuit made by parallel connection of FU-50
- Stereo phono amplifier circuit with bass control composed of LM1877
- LM4902 differential input audio amplifier circuit
- Typical circuit of LM4809/LM4810 for dual-channel headphone amplifier
- Horseshoe gallbladder preamplifier circuit
- Application of BTL power amplifier circuit composed of LM3886
- Platinum thermal resistance signal conditioner internal circuit block diagram and typical application circuit
- Application circuit to increase output voltage
- AC-SSR application circuit d
- PSZ739 application circuit
- M50194AP application circuit
- Internal circuit and application circuit of BA3884 (a)
- Application circuit of TEA0665
- Application circuit of HA12058
- Application circuit when using single power supply
- AP500 and its application circuit (e)
