Internal circuit principle of TA8173
Source: InternetPublisher:公子李 Keywords: Circuit principle BSP channel low-pass filter Updated: 2021/02/24
The internal circuit principle and application are shown in Figure 5-26. It has two input terminals and two output terminals.
The external selection switch SA on pin 13 is used to select the surround sound or direct working state. It can
be seen the ordinary two-channel signal passes through 14 and 16 After pin input, it is amplified by the buffer amplifier and divided into the main channel and
the sub-channel obtained by subtracting R and L. After passing through the low-pass filter , it undergoes phase shift and delay, and then passes through the external selection of pins 1 and 3.
The selection control of the switch is a forward addition with the R channel of the main channel and an inverse addition with the L channel. After passing through the low-pass filter
it is output from pins 9 and 11 respectively . The synthesis ratio of the sub-channel is 2 ( R - L) can
be adjusted by the potentiometer RP connected between pins 2 and 15.
The working voltage of TA8173AP is 5~12V, the quiescent current is 6.3mA at 10v, the frequency response is 8kHz
~ 20kH, total harmonic Wave distortion is 0-026%o
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- Installation of electron tube differential amplifier circuit
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- Minimum output noise/reduced output power circuit using LM4910
- 1OW audio power amplifier circuit using UPC1238
- A common-phase audio power amplifier circuit powered by a split power supply using LM1877
- Protection circuit and maintenance of household audio power amplifier
- 8W audio power amplifier circuit composed of LM2002/LM2002A
- Audio amplifier circuit of the Expo flowerpot speaker
- strain sensor
- Inpatient pager circuit
- Agricultural temperature control circuit
- Rural fish farming control circuit
- DC ammeter
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Capacitive feedback oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage-controlled voltage source second-order band-pass filter circuit
- Sine wave signal generator circuit
