Internal circuit and application circuit of BA3884 (b)
Source: InternetPublisher:蓝猫淘气 Keywords: Application circuit BSP frequency band DC voltage Updated: 2021/10/15
The DC operating voltage of BA3884 is 5.4~12.3V. Its internal circuit principle and application circuit are shown in Figure 5-16.
This circuit is a two-channel processing circuit, containing two sets of identical processing circuits. It can complete the following audio signal processing.
Phase compensation. The audio signal is input into the two channels of the LC through pin 14.23, and is divided by the low-pass filter LPF, the band-pass filter BPF, and the high-pass filter HPF into
three
channels: 20-150Hz, 150Hz~2.4kHz and 2.4kHz~20kHz The frequency bands are processed separately, and finally the processed signals are added and synthesized and output from pins 13 and 24 respectively. Since
the fundamental wave of sound is located in the mid-frequency band and the higher harmonics are located in the high-frequency band, in order to eliminate the phase distortion caused by high delay, this
circuit adopts a fixed high frequency, so that the mid-range band lags behind the high-frequency band by 1 80. , the bass band
lags behind the treble band by 3600. Due to the hysteresis processing of the mid-range and bass bands , the delay phenomenon of the high-frequency bands
is exactly compensated and corrected, and the phase distortion is eliminated.
Amplitude compensation (harmonic compensation) o In order to compensate for the speaker's insufficient amplitude response to high-frequency harmonics, the high-speed peak detector
and voltage-controlled amplifier VCA automatically control the amplitude of high-frequency harmonics as needed. Correction and compensation
are controlled by two DC voltages. One DC voltage is provided by an external voltage divider circuit and is added to the CTL ① terminal; the other DC voltage
is obtained by detecting the input signal by the peak detector, and is added by the high-frequency harmonics of the HPF. To the VCA input end,
compensation correction is completed by a special circuit. After amplitude correction, the harmonics reflecting the subtle characteristics of the sound are restored and strengthened, allowing the playback system to produce high-
resolution, high-definition and natural-sounding sounds. The DC voltage applied to the CTL1 terminal is adjusted by the base)2 of the voltage divider circuit. When it is turned on
When switch K is placed in the "ON" position, it is the BBE working state. When the voltage of pin 8 of CTL1 changes from 4.5V-Oy,
the resolution and clarity of the audio signal processed by IX
are improved by OdB9, 5dBo bass contour. To restore the phase and amplitude of high-order harmonics, appropriate bass is needed to achieve the best balance. The processing
system uses a bass contour boost circuit to achieve the most ideal linear boost from the range of 50 N150Hz. The boost
circuit is improved by Adjusted by the voltage divider circuit RPi, when the DC voltage at pin 7 of rL2 changes from 4.5V to OV, the bass
boost amount increases from OdB+8.7dB. Through the bass boost, the entire sound playback system achieves balanced high and low sound playback.
- 6P3P parallel 20W power amplifier experiment
- Two unique tube preamplifiers
- Converting a microphone preamplifier (RJ4558) into a headphone amplifier
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- 6AS7 tube amplifier
- LM4902 differential input audio amplifier circuit
- LM4906 Audio Power Amplifier Circuit
- LM4820-6 audio power amplifier circuit
- Audio amplifier circuit of the Expo flowerpot speaker
- Stereo amplifier circuit with Av=200 (gain) composed of LM1877
- electromagnetic field sensor
- Agricultural small tractor lighting circuit
- Poultry warming temperature control circuit
- Diode Balanced Mixer Circuit
- Frequency modulator composed of NE566
- ring amplitude modulation circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- OTL low frequency power amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Sawtooth wave generator circuit (2)
