Dolby IC CX1100 series and applications
Source: InternetPublisher:无人共我 Keywords: amplifier adder Updated: 2020/09/09
It is the internal circuit principle and application of CXA1100 series IC. In the picture, SAt is the Dolby switch, and SAz is the record/
playback switch. When SA2 is placed in the recording (R) position, the recording signal enters the A amplifier through the l (16) pin for amplification.
The amplified signal is sent to the main channel adder , the variable attenuation circuit of the auxiliary channel and the B amplifier respectively. Part of the signal output by the B amplifier
enters the adder through the high-pass filter and is added to the main channel signal, so that the high-frequency small signal is improved;
the other part is amplified by the C amplifier and rectified and filtered by the rectifier filter, and then to the variable The attenuator circuit provides the DC control
voltage. One of the signals output from the adder is sent to the recording head as a recording signal through pin 8 (9); the other
is sent to the A amplifier through the feedback circuit to subtract the input signal , so that high-frequency noise is suppressed.
- Share a mini piano circuit
- Homemade high quality preamplifier tone circuit
- Field effect tube amplifier circuit with beautiful sound
- Make cheap speakers using waste circuit boards (TDA1013)
- A very simple amplifier
- Inverting power amplifier circuit composed of LM4732
- Stereo phono amplifier circuit with bass control composed of LM1877
- Class AB2 Amplifier-McIntosh MC80
- LM4903/4905 high gain audio amplifier circuit
- 8W audio power amplifier circuit composed of LM2002/LM2002A
- Essentials of making a tube amplifier
- New speaker coupling circuit diagram
- Fiber optic transceiver circuit diagram
- Ultrasonic proximity sensor circuit
- High input impedance three op amp differential amplifier circuit diagram
- MC-1590 IF amplifier circuit diagram
- Low drift peak detector
- Operational transconductance amplifier with booster
- Parallel power op amp
- non-diode rectifier
