New speaker coupling circuit diagram
Source: InternetPublisher:MartinFowler Keywords: Amplifiers power supplies and other power circuits Updated: 2021/01/20
![141040186.jpg](http://www.eeworld.com.cn/circuit/upload/cee943e92aacfdc3a8b64d1b08df5230/7020b6194aa3566c307a6290d3e508f3.jpg)
The speaker's ground terminal is connected through the node between the power supply and two equal high-value capacitors (typically 1000 μF). The output voltage of the amplifier is VS/2, and the voltage will pass through C1 (if C1 is equal to C2). Like the power supply voltage, the DC voltage remains at zero after passing through the speaker, and will not surge even after it is turned on.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- 5 Converter Topologies for Integrated Solar and Storage Systems
- ISO113 circuit that can reduce power consumption
- Driving circuit that controls LED brightness using PWM signal
- Voltage-current converter constructed with XTR110
- Adjustable regulated power supply with current limiting protection
- An ultra-low output voltage regulator
- 3~15V 10A adjustable voltage regulated power supply
- Design of electric vehicle charger
- Battery powered switching circuit diagram
- Variable gain operational amplifier circuit diagram
- How to use "virtual short" and "virtual break" to analyze op amp circuits
- simple audio mixer
- TDA2030A subwoofer circuit diagram
- High input impedance three op amp differential amplifier circuit diagram
- Differential bridge amplifier circuit diagram
- Adjustable output voltage regulator circuit diagram
- Ultrasonic proximity sensor circuit
- A crystal controlled local oscillator circuit diagram
- OTL low frequency power amplifier circuit
