Delay, reverb unit circuit
Source: InternetPublisher:3228 Keywords: Unit circuit BSP Updated: 2021/04/13
Delay sound unit. As shown in Figure 3-30,
the BBD-type simple delay reverberation circuit composed of IC 701 (LM324), IC702 (MN3207, IC 703 (MN3102), etc.) is specially designed for four microphone inputs and is controlled by a "reverberation switch"
I controls
its connection or cut-off. When SA701 is connected to the "OFF" position, the delay reverberation circuit does not work. The microphone signal is connected to the bus of the left and right channels through
R119 and R122 respectively, and passes through R119 and R122. l, CS02, and R802 are directly sent to the input terminal A of the main amplifier
. When l is connected to the "ON" position, the four microphone input signals are connected to the input terminal of the delay reverberation device through R120 and the
processed signal Then connect the left and right sound busses through RP70z, R706, and R70 respectively. If you require the sound system to obtain a delayed reverberation effect, you can
connect another one to
the external effect terminal (EFFECT. OUT/1N) of the main amplifier.
Professional delay amplifier or effector.
- Echo Dot speaker intelligent control system solution
- Simple and practical small amplifier
- Design and production of class AB headphone amplifier
- FU-7 Tube Amplifier Homemade
- Telephone volume amplifier circuit
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- LM4766 Dual 40W+40W Power Amplifier
- 2W×2 power amplifier circuit using LM1877
- Single power supply audio power amplifier circuit composed of LM3875
- Multimedia Hi-Fi amplifier circuit
- Farmland irrigation automatic control circuit a
- DC ammeter
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Varactor Diode Frequency Modulator
- ring amplitude modulation circuit
- Crabo oscillator circuit
- Inductive feedback oscillator circuit
- Voltage series negative feedback amplifier circuit
- Guest arrival signal recognition circuit
- Small current generator circuit
