Multi-channel microphone input amplifier
Source: InternetPublisher:containsmachine Keywords: amplifier mixed signal noise Updated: 2020/01/05
It is a four-channel microphone input hybrid amplifier composed of BA328. It has the advantages of low noise and fewer external components
. oBA328 is a two-channel preamplifier integrated circuit composed of two amplifiers. It
is composed of two BA328 and has Mixing amplifier with four microphone inputs. It can insert four high-impedance microphones at the same time.
After the signals picked up by the microphones are amplified by their respective amplifiers, they pass through the coupling capacitor clt~C14 and get a mixed signal output at both ends of R13. In order
to facilitate the connection of the output mixed signal to the microphone input jack of the amplifier, the mixed amplifier intentionally reduces
the gain of the amplifier. The output signal level of each channel is realized by adjusting the control potentiometer RPi ~ Gang) 4 of. Since the gain of this
amplifier is low, it works stably. When using it, just use a shielded wire to directly connect the mixed output signal to
the microphone input jack of the amplifier. If the mixed signal of this output is required to be connected to the line input jack, the gain of the amplifier
should
be adjusted to 40dB. At this time, just change the feedback resistor Rz, wind, R6 and Rs to a resistance of 15 kfl.
- How to adjust the bass and treble of CXA1005
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Make the most beautiful sound with the least money
- DIY 50W Gallstone Amplifier
- Make a pocket amplifier with 8550 and 8050
- 6N5P tube direct-coupled single-ended amplifier
- Installation of electron tube differential amplifier circuit
- Inverting power amplifier circuit composed of LM4732
- Typical circuit of LM4809/LM4810 for dual-channel headphone amplifier
- Audio amplifier circuit of the Expo flowerpot speaker
- Minimize noise and ripple using low-noise buck converters
- Single Supply Op Amp Applications
- New speaker coupling circuit diagram
- Based on TDA2009 power amplifier application line circuit diagram
- MC-1590 IF amplifier circuit diagram
- Amplifier circuit diagram based on 50Ω linear
- Active load differential amplifier circuit diagram
- LTC2053 thermocouple amplification circuit diagram
- Differential bridge amplifier circuit diagram
- Multi-channel microphone input amplifier
