Ten-band frequency equalizer
Source: InternetPublisher:smallembedded Keywords: MDASH transistor bandpass filter amplifier Updated: 2021/06/03
Figure 1-97 is a ten-band equalizer circuit composed of the first connection method.
lC in the figure is a common voltage amplifier , R7 and island are respectively equivalent to Rl, R2, VTr-VTio in Figure 1-92.
The ten transistors are the main body of the analog inductor. ‰~C39 are the resonances of the band-pass filters in
each frequency band. Capacitance, equivalent to
C1 in Figure 1-93 (b), C20 ~ lC29 is equivalent to C2 0
- Share a mini piano circuit
- Echo Dot speaker intelligent control system solution
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- Making a Simple Tube FM Radio
- Toy electronic chicken
- Make cheap speakers using waste circuit boards (TDA1013)
- Volume synchronization circuit constructed with discrete components
- LM4902 differential input audio amplifier circuit
- Tube single-ended class A 300B power amplifier circuit
- American Grado RA1 headphone amplifier
- Six common constant current source circuit diagrams and analysis
- Circular drive circuit diagram composed of 3 triodes
- Acousto-optic digital level detector circuit diagram
- Triode color changing flash circuit diagram
- White noise electronic lullaby circuit diagram
- Lightning protection wiring c for direct distribution generators from 300 to 1500kW
- Infrared anti-theft alarm circuit one a
- Simple buzzer circuit one c
- Multiple sets of light-emitting diode lantern chain circuits with different flashing frequencies a
- The simplest single differential OCL power amplifier circuit diagram
