Practical equal loudness control circuit
Source: InternetPublisher:JFET Keywords: Control circuit BSP volume control power saving Updated: 2020/04/02
Figure 1-91 is a practical circuit with an equal loudness volume control circuit added . It is inserted between the preamplifier and the tone control circuit
, and can be connected to the main amplifier circuit such as OCL. Practical results have proven to be effective. Even when the volume is turned up very low,
clear and soft bass can be obtained. The output stage of the preamplifier uses an emitter output device with a constant current source, thus ensuring low
output impedance and good following characteristics. Its operating current is adjusted between 4 and 6mA. Even when the load is small,
it can have sufficient signal level output and ensure minimal distortion (when the volume is zero, the load of the preamplifier is
It is a low-resistance Ri)o
loudness volume controller that uses a field effect transistor, and has a high input impedance and a very low noise figure. This circuit
does not require high compensation. If the treble is insufficient during use, you can add high frequency compensation according to the dotted line in the figure and adjust the resistance to change
the degree of compensation.
- Share a mini piano circuit
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- A high-quality tube amplifier with 6P3P design
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Make the most beautiful sound with the least money
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- 6BX7 10W bile duct amplifier
- Typical applications of optocouplers in audio amplifier circuits
- Class A power amplifier circuit with an output power of 18W
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- Electronic anti-asthma circuit
- Crop anti-frost circuit
- Rural fish farming control circuit
- Rural vegetable greenhouse lighting circuit
- Agricultural spraying and insecticide control circuit
- Farmland irrigation automatic control circuit b
- Simple AGC circuit in transistor radio
- Crabo oscillator circuit
- Differential Amplifier Circuit
- Voltage controlled power supply second-order high-pass filter circuit
