Field effect transistor OCL power amplifier circuit
Source: InternetPublisher:李商隐身 Keywords: Power amplifier circuit field effect transistor OCL BSP Updated: 2021/11/24
It is a fully symmetrical OCL power amplifier circuit composed of field effect transistors
VTi ~ VT4 form a fully symmetrical dual differential input stage, which has a very high common mode rejection ratio o
VTs. VT6 forms a FET active load type push-pull voltage amplification stage, which has a high voltage amplification factor.
VT7 and VT8 form a complementary push-pull power amplifier output, and the 1000 resistor connected to their gate is the gate
current limiting resistor. The 1-Sfl resistor connected to the source is mainly used to test the quiescent current during debugging. Although the negative feedback generated on it
has a protective effect similar to that of the emitter resistor of a transistor, for MOS power amplifier tubes, because its drain
current itself has a negative temperature coefficient, it is useless without a source resistor. How big a deal.
This amplifier does not use resistors in the AC negative feedback circuit, but uses a capacitor AC negative feedback circuit. Doing this
can improve the sound quality. The amplifier gain is determined by the voltage division ratio of the 1200pF and O,OliuF capacitors, which is about 9-3 times. If
the o-ol center is changed to O,1plF, the gain is close to 100 times.
Adjusting RPz can adjust the output midpoint voltage, and adjusting 剉)3 can adjust the quiescent current of the output tube. The quiescent
current of this machine is 10mAo.
- The easy production of several top-quality tube preamplifiers
- Field effect tube amplifier circuit with beautiful sound
- 6AS7 tube amplifier
- Electronic bird repeller for crops
- Typical application circuit of LM4903/4905 audio power amplifier
- LM4902 differential input audio amplifier circuit
- Improved Marantz 7-tube preamplifier circuit
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- Typical circuit of LM4809/LM4810 for dual-channel headphone amplifier
- LM4819 high gain audio amplifier circuit
- Excellent performance household inverter power supply circuit
- Self-defense anti-riot circuit
- Chicken supplementary light to increase egg production rate circuit
- Farmland irrigation automatic control circuit b
- DC ammeter
- Schiller oscillator circuit
- superheterodyne radio circuit
- color discrimination circuit
- Digital stopwatch display circuit
- Sawtooth wave generator circuit (1)
