The simplest structure OCL power amplifier
Source: InternetPublisher:桂花蒸 Keywords: OCL power amplifier BSP composite tube Updated: 2021/11/23
The circuit structure is very simple, but the performance is very good. There can be almost no less components used in the circuit, which not only reduces
production costs, but also makes debugging very simple. Its principle is shown in Figure 2-5.
VTl and VT2 use a differential input stage composed of an extension tube, which is
different from the structure of most input stages that use NPN tubes. The advantages of using napkin tubes are that the tubes are easier to match and have better consistency, and the operating noise is lower.
VT3 serves as both a voltage amplification stage and an output drive stage, so it is required that this stage should have a higher voltage gain
in order to provide sufficient drive power for the output stage.
VT4~VT7 form a composite fully complementary push-pull output stage, vT5 and Vr7 form a complementary push-pull PNP pole composite tube , and
VT4 and VT6 form an NPN pole composite tube. Both sets of composite tubes are combined in the simplest structural manner,
reducing circuit components and eliminating the need for adjustments. However, the penetration current requirements of VT4 and VL in the composite tube
are extremely small to ensure
the stability of the circuit operation.
- How to adjust the bass and treble of CXA1005
- Field effect tube amplifier circuit with beautiful sound
- Installing a tube preamplifier in the power amplifier
- Typical application circuit of LM4903/4905 audio power amplifier
- LM4915 is used for dual-channel amplifier circuit
- 8W audio power amplifier circuit composed of LM2002/LM2002A
- Differential input audio amplifier circuit composed of LM4904
- Audio amplifier circuit of the Expo flowerpot speaker
- Stereo amplifier circuit with Av=200 (gain) composed of LM1877
- American Grado RA1 headphone amplifier
- Smoking Cessation Circuit
- High-efficiency speaker circuit for rural stage
- Egg warming circuit
- Agricultural small tractor lighting circuit
- Greenhouse temperature control circuit
- Farmland irrigation automatic control circuit a
- Inductive feedback oscillator circuit
- Broadband high frequency power amplifier circuit
- High and low frequency signal generator circuit
- Motorcycle flash light circuit
