Full-wave synchronous detection circuit using analog switch IC
Source: InternetPublisher:toothache Keywords: Analog switch detector circuit BSP Updated: 2021/06/23
OP amplifier, 2 is a balanced output circuit that obtains positive and negative phase input H{.
It can also be replaced by a balanced transformer with a center tap, but in the low frequency range, it
is more advantageous to use an OP amplifier. Resistor R: The ratio to Ra is 1, and it is not necessarily limited to
lOkQt.
In the circuit, the analog switch crCz) plays an important role. The contact position in the circuit diagram
connects the in-phase output (Ai output, that is, the positive half cycle of the input signal). On the inverting input of the OP amplifier, A3 is an inverting
amplifier
with an amplification factor of I.
If the switch contact is switched downward, the inverting output (also output, the input signal
is a negative half cycle) is turned on (the same phase as REF, the Az output is positive), so an
inverting output port with an amplification factor of 1 can be obtained. Consider One input signal period,
■'the output terminal obtains a negative barrier wave output.
- How to test whether the multimeter is working properly
- Lightweight and practical multi-core cable detection circuit
- Simple and practical EPROM detection circuit
- Balcony intelligent invisible anti-theft net
- New function added to MF-47D multimeter - infrared remote control detection
- Using NE555 to make diode and triode detector
- A low-cost inductance meter consisting of a single IC
- Low resistance connection tester circuit diagram sharing
- Phase sequence indicator circuit diagram
- Multimeter DC voltage measurement circuit
- Greenhouse temperature control circuit
- Egg heating control circuit
- Farmland irrigation automatic control circuit a
- Domestic KD8041 integrated phase locked loop
- Double detuned loop frequency discriminator circuit
- Varactor Diode Frequency Modulator
- Series crystal oscillator
- Parallel crystal oscillator
- Sawtooth wave generator circuit (1)
- Sine wave signal generator circuit
