Small improvements to the rechargeable flashlight
Source: InternetPublisher:三月小雨 Keywords: Flashlight leakage protector hot melt Updated: 2020/09/02
Commercially available rechargeable flashlights generally use the circuit shown in Figure 1 and are directly connected to the mains when charging. Since the circuits are sealed within the plastic shell of the flashlight, there is generally no risk of electric shock. But there are exceptions. Once, I accidentally unscrewed the condenser cover at the front of the charging flashlight and touched the small electric beads inside. Fortunately, a leakage protector was installed at home and the power supply was cut off in time, otherwise the consequences would be disastrous.
The author made a small improvement to the flashlight according to Figure 2 and separated the power supply from the battery charging and lighting circuits to improve safety. The method is as follows: remove the original power switch and use a small high-quality double-pole double-throw switch. Connect the switch wires according to the diagram, and then insulate the pins on the switch with hot melt glue.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- 220V Remote Load Monitor
- Practical and convenient fax machine power supply control circuit
- Single-power supply circuit for ISO122P/ISO124
- Driving circuit that controls LED brightness using PWM signal
- How to use SBR to improve power conversion efficiency
- Integrated regulated power supply with continuously adjustable output voltage
- USB power socket using the car battery
- MAX1811 Lithium Battery Charger Production
- Circuit diagram explanation: simple switching power supply circuit diagram
- Switching power supply circuit composition and detailed explanation of each part (1)
- Power supply circuit design optimized for digital light projectors
- Power circuit b composed of intelligent thyristor modules
- Current leakage protector circuit
- Commonly used power circuits in printers
- Wiring a when the leakage protector supplies power and lighting loads in the TN system
- Wiring a when the leakage protector in the TT system supplies a three-phase balanced load
- JBD3-10 leakage protector circuit
- One of the light control switch circuits controlled by flashlight
- Light control switch circuit 3 controlled by flashlight
