Application of LM3886 in home theater 03
Source: InternetPublisher:JFET Keywords: Home theater LM3886 BSP Updated: 2020/06/29
(3) Subwoofer active speaker.
Figure 10-13 is a home subwoofer active speaker circuit. In the figure, the Linkwitz active compensator accurately controls
the center frequency F and Q value of the compensation peak, and can make a closed box with a natural turning frequency of about 50Hz. The power circuit
is shown in Figure 10-14, and the frequency response curve is shown in Figure 10- As shown in 15, it extends downward gently, and the low-end 3dB
point reaches 25Hz. Curve a in Figure 1 0·1 5 is the natural frequency response, and b is the compensation curve.
c is the system frequency response. The turning frequency of the low-pass filter is continuously adjustable from 80Hz to 200Hz
, so that the active subwoofer can match the reader's two-channel speakers with different lower frequency limits. The
protruding speaker is Yindi YD310-43, with a basin diameter of 310mm and a magnet
diameter of 158mm. . The resonance frequency is 25Hz, Q=0.35. The continuous power is 50w. The
sensitivity is as high as 95dBo. Compared with the Hivi S8 unit with a sensitivity of 88dB,
the sensitivity difference between the two is 7dB. If the box is closed at the same time, the output sound pressure of Yindi YD310-43 when sow is input is equivalent to
the input of the Hivi S8 unit ≥ Output at 200W. You can also use Nanjing YD310-8XA to replace the silver flute. The cabinet should not use an inverter box with poor transient performance and low sensitivity
, but should use the simplest closed box. The cabinet should be strong and airtight, and should be filled with fiberglass cotton or acrylic cotton for saliva protection.
- Design and production of class AB headphone amplifier
- Converting a microphone preamplifier (RJ4558) into a headphone amplifier
- Preamplifier made of 6P15 tube
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- 6BX7 10W bile duct amplifier
- Dual power supply audio power amplifier circuit using LM1875
- Improved Marantz 7-tube preamplifier circuit
- Multimedia Hi-Fi amplifier circuit
- 8W audio power amplifier circuit composed of LM2002/LM2002A
- Audio amplifier circuit of the Expo flowerpot speaker
- electromagnetic field sensor
- Pulse therapy circuit
- Inpatient pager circuit
- Mixer built with analog multipliers
- Double detuned loop frequency discriminator circuit
- Parallel crystal oscillator
- Differential Amplifier Circuit
- Second-order active band-stop filter circuit
- color discrimination circuit
- Small current generator circuit
