Make your own home theater AV combo with superior performance 05
Source: InternetPublisher:睡不醒的小壮 Keywords: Home theater BSP stereo Updated: 2021/12/24
The AV combination is shown in Figure lo-2. The first stage uses Philips
TDA1029 as a four-way input switching signal switch; the second stage uses
NE5532 as a preamplifier and B-NEC's pPC18 92
four-way surround sound processing circuit. Main signal and surround, center signal output,
and control of high and low tone, volume, left and right channel balance, surround effect control
and three sound field effect simulation options; the third stage uses MS381 to
achieve three-dimensional optimization of the front pair of speakers Sound field effect processing; the suffix
is TDA1514A and TDA15 21 (or LM1875) for power output
. TDA1029 is a stereo four-way high
-fidelity audio signal switching integrated circuit
used in the audio field . Working voltage: 6~23V, typical
value is 12V, total harmonic distortion is only 0.005%, excellent signal-to-noise ratio (V=120dB), conversion rate 5-15V/Ftso
typical application circuit is shown in Figure 10-3 Show.
ruPC1892 is a four-channel surround sound processing circuit with excellent performance launched in 1995. The circuit adopts a matrix phase-shifting
surround sound processing system, which can separate the two-channel signal and the mono-channel signal into two main channel signals and One surround channel signal and one
center channel signal (during actual production, it was found that
one of the two sub-channel signals of PC1892 is
the center signal) o This circuit is equipped with concert halls,
cinemas and analog stereo and stereo Pass-through sound field effect
mode. The circuit is equipped with surround sound effect control, main
amplifier balance, treble, bass and volume control inside the circuit. Some of the controls
adopt DC level control, which
reduces the noise of the circuit to a very minimum. Anal P ('1892 is equipped with amplifier
, low-pass filter, mode control 1 phase shift, effect
processing, compensation absorption, tone, volume, balance and other
circuits inside. pcPC1892 is a large-scale integrated circuit.
The application circuit is as shown in the figure . As shown in 10-4, the typical operating voltage
is +12V, and the control part uses +5V. The audio mode
control is controlled by the high and low level
programming . The functions of each potentiometer are as follows: RP1 is the back surround channel Sound effect volume control, RPZ is the front left and right channel ear
balance control, RP3 is the left and right channel volume control, RP4 is the front center channel volume control, RP5 and RP6 are the low and treble tone controls of the front left and right
channels .The function of turning si and S2 is: sl high level and sz low level are concert hall mode; sl
low level and S2 high level are cinema mode; sl and SZ both high level are analog stereo mode; Sl . S2 is both low level and is a stereo pass-through state port.
- Homemade high quality preamplifier tone circuit
- Practical and high-performance preamplifier circuit
- FU-7 Tube Amplifier Homemade
- The fun of making ISD1820 voice recording box
- Design and production of NE5532+TDA1521 amplifier
- Stereo tube power amplifier
- Audio power amplifier circuit powered by a single power supply using LM1875
- Bridge output audio power amplifier circuit composed of LM1876
- LMl876 is used to assist the audio power amplifier circuit
- Audio amplifier circuit of the Expo flowerpot speaker
- Homemade disinfectant circuit
- soil content measurement circuit
- High-efficiency speaker circuit for rural stage
- Rice mill circuit
- Crop anti-frost circuit
- Rural fish farming control circuit
- Diode Balanced Mixer Circuit
- Simple AGC circuit in transistor radio
- Wireless microphone circuit
- Digital stopwatch display circuit
