Pure DC FET power amplifier circuit 02
Source: InternetPublisher:天天都吃好吃的 Keywords: Power amplifier circuit field effect transistor BSP Updated: 2021/11/21
22. This field effect tube amplifier is suitable for those who are obsessed with the sound of electronic tubes but cannot produce beautiful sounds for various reasons.
Audiophile 9 This bipolar field effect tube amplifier has very similar output characteristics to those of electronic tubes. The frequency characteristics Good, the tone
is similar to that of the amplifier and amplifier, and it is more ideal if it is coupled with a tube preamplifier. Q SRPP tube preamplifier circuit, as shown in Figure 7-256.
The circuit is a parallel adjustable push-pull circuit, and the fork can be called The shunt-adjusted push-pull circuit was originally used for high-frequency input stages, such as
VHF/UHF tube high-frequency head circuits, but is used for AF input, regardless of distortion, linearity, amplification, dynamics and low
output impedance. It is comprehensively superior to ordinary Class A triode amplifiers, and contrary to many other tube circuit designs,
the distortion rate of the SRPP circuit decreases as the frequency increases.
This circuit is obviously two tubes connected in series. How can it be a parallel adjustable push-pull circuit? This is for AC work , the DC
power supply mode
of the two tubes is connected in series, each carrying half of the power supply voltage. But it is different for AC signals.
The screen electrode of the upper tube is connected to the ground. The input is taken from the screen electrode of the lower tube, and the negative output (shared screen circuit) is used. In this way, the tubes
work in parallel. . Because the gate of the electron
tube works at a negative angle relative to the cathode
, the bias circuit is extremely simple. This principle cannot
be used in transistor or op amp circuits.
- How to Measure Turbidity of Liquids Using Arduino
- Simple and easy to make zero degree detector
- Convenient and fast power line break detection circuit
- Temperature Range Monitoring System
- Homemade refrigerator monitor
- Infrared detector
- Temperature-frequency conversion circuit composed of CD4046
- A simple electronic muscle stimulator circuit
- An electronic load meter using LM324 operational amplifier as the main control device
- Three-phase three-wire active energy meter connected to three ammeters
- Set timing circuit when power is on
- Bone hyperplasia treatment circuit
- High-efficiency speaker circuit for rural stage
- Rice mill circuit
- Crop anti-frost circuit
- Fish farming thermostatic control circuit
- Series crystal oscillator
- Parallel crystal oscillator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage series negative feedback amplifier circuit
