High performance DC power amplifier drive circuit AP500A-01
Source: InternetPublisher:天天都吃好吃的 Keywords: Power amplifier drive circuit DC PLUSMN Updated: 2021/11/10
Because AP500A has so many advantages mentioned above,
its application in audio has incomparable advantages.
AP500A can be used to produce various
unique power amplifier circuits such as OTI, ") CI, rK,
BTL, Class A and B, super Class A, Class A, etc. Figure 3-21 and Figure 3-22 are
typical AP500A DC power amplifier application circuit is shown in Figure 6. The AP500A module
is used for voltage amplification of the power amplifier and drives the VT1 and VT2 power amplifier
tubes. VT1 and VT2 are responsible for the current amplification tasks of the power amplifier. Figure
3-22 uses a VMOS field effect power amplifier tube. The VM with
electronic tube characteristics ()S power amplifier tube is used with AP500A with DC field effect input
, which can give full play to
the unique
characteristics Figure 3-23 is the power supply circuit of this power amplifier, Figure 3 —21,
3-22 When using ±42V power supply, the output power is up to 2,
oow
Within the operating voltage range (including ±4zv, ±
28V), the circuit can work normally without debugging. Those who have strict requirements on the working status of the power amplifier tube can
connect an adjustable resistor as shown by the dotted lines in Figure 3_21 and Figure 3-22. To set the working status of the final power amplifier tube VTl.VT2 (such as Class B, Class A, B or
Class A, you can also connect some auxiliary components to the peripheral circuit to make VTlVT2 enter the super Class A working state). In addition, because the power amplifier
The tube is used for current amplification in the final stage of the power amplifier , and its power consumption is large, so an auxiliary radiator with a heat sink is required.
- How to test whether the multimeter is working properly
- DIY Multimeter High Frequency Signal Probe
- Simple electric tachometer
- Simple infrared detector
- Digital strain gauge circuit using MAX1492/MAX1494
- PHGS-4 computer multi-channel industrial acidity meter circuit 01
- Typical two-stage low-pass filter circuit
- voltage amplifier circuit
- DS8 type 100V, 5A mutual inductance three-phase three-wire electric meter wiring
- Temperature voltage conversion circuit
- MC3406A step-down DC-DC integrated converter
- Radio remote control doorbell circuit c
- Radio remote control doorbell circuit b
- DC-RRS application circuit a
- DNC-X50E special switching power supply
- AP500 and its application circuit (e)
- AD2S80A, AD2S81A, AD2S82A RDC monolithic integrated circuits
- DC/DC conversion circuit diagram without isolation
- Multi-output DC and DC converter circuit diagram composed of L4970A
- 3V-12V DC DC conversion circuit 2
