High-fidelity power amplifier quasi-complementary symmetry (OCL) circuit
Source: InternetPublisher:无人共我 Keywords: Amplifier OCL speaker Updated: 2021/01/10
▲ Circuit diagram principle
Circuit structure: T1 and T2 are differential amplifier input stages, T3 is a common emitter amplifier stage and T4~T7 form a quasi-complementary power output stage.
R7, D1, and D2 provide bias voltage for T4~T7 tubes to overcome crossover distortion.
R1 and R6 form the base current loop of T1 and T2 tubes respectively, and R6 forms DC negative feedback to stabilize the static operating point of the entire circuit. R6, C3, and R5 form AC voltage series negative feedback, which stabilizes the voltage amplification, increases the input resistance, decreases the output resistance, and reduces the nonlinear distortion.
C6 and R9 are bootstrap circuits, which are designed to fully utilize the final stage complementary symmetrical tube in order to increase the amplitude of the collector output voltage of the T3 push stage.
C5 plays the role of frequency compensation and eliminating self-oscillation; R14 and C7 are used to overcome the influence of the inductive load in the speaker and make it close to pure resistance to protect the output power tube and also help to avoid self-excitation.
In order to get the output stage to a suitable operating point, R10 and R11 simultaneously reduce the penetration current of T6 and T7 respectively, and increase their breakdown voltage value.
ck="window.open(this.src)" alt="Click to see larger image" />
▲Circuit adjustment
The static potential at point A at the output end of the OCL circuit should be zero.
If VA≠0, R2 should be adjusted. If VA>0, R2 should be adjusted smaller.
When adjusting the static potential of the output end, the speaker should be disconnected from the circuit and replaced with a dummy load to avoid burning out the speaker when VA≠0
When a sinusoidal signal is added to the input end, if the output waveform produces cross distortion, the R7 potentiometer should be adjusted to the minimum first, and then gradually increased to make the cross distortion just disappear. If R7 is too large, the current of T6 and T7 may be too large and the tubes may be burned out. When VA=0, adjust R7 to make VA≠0, so R7 and R2 should be adjusted alternately and repeatedly until VA=0 and the cross distortion is just eliminated.
- Tutorial on making a MIDI arpeggio synthesizer
- Two unique tube preamplifiers
- Sugon New Tube 2A3C Single-ended Tube Amplifier
- Making a Simple Tube FM Radio
- The production of 6P14 small tube amplifier
- 6AS7 tube amplifier
- Volume synchronization circuit constructed with discrete components
- LM4901 audio power amplifier circuit (MSOP package)
- LM4820-6 audio power amplifier circuit
- Differential input audio amplifier circuit composed of LM4904
- TW-42 ultra-short wave radio transmitter high frequency power amplifier circuit part
- Integrated circuit OCL power amplifier circuit
- BTL power amplifier composed of dedicated circuits
- OCL power amplifier circuit
- Production of high-quality active two-way constant current power amplifier 02
- Nx75W integrated power amplifier components
- 20W 40-500kHz power amplifier 01
- Imitation AURA-VA50 amplifier
- Typical OCL power amplifier circuit
- The simplest single differential OCL power amplifier circuit diagram
