Application of LM3886 in home theater 01
Source: InternetPublisher:拿铁三分糖 Keywords: Home theater LM3886 BSP power amplifier Updated: 2020/09/06
(1) How close is the continuous output power of the high-quality two-channel power amplifier
LM3886 at the rated voltage? ow, the peak power can reach 150w. The dual-channel amplifier adopts simple and
typical circuits and can replace a variety of mid-range and low-range fever amplifiers. It is suitable for use as the left and right main channel amplifiers in home theaters . The entire circuit is installed on the same
PCB. Two IJM3886s are equipped with a special aluminum radiator with a length of 1.40, a thickness of 5.0 and a height of 75 (mm) fixed on
both sides of the PCB to facilitate heat dissipation. The power transformer can choose dual 24~28V, 3r __5A ring cattle.
- Field effect tube amplifier circuit with beautiful sound
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Installing a tube preamplifier in the power amplifier
- 6C16+FU50 high-fidelity tube amplifier circuit with unique sound
- The production of 6P14 small tube amplifier
- 6BX7 10W bile duct amplifier
- LM4902 differential input audio amplifier circuit
- LM4903/4905 differential input audio amplifier circuit
- LM4915 is used for dual-channel amplifier circuit
- LM4820-6 audio power amplifier circuit
- Motor overcurrent protection circuit
- Ultrasonic blind pathfinder circuit
- Smoking Cessation Circuit
- Peanut and melon seeds roasting machine circuit
- Soil water shortage prompt circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- AC voltmeter
- Mixer built with analog multipliers
- Crabo oscillator circuit
- superheterodyne radio circuit
