1 to 2W audio power amplifier for easy in-instrument installation
Source: InternetPublisher:王达业 Keywords: Instruments Audio Power Amplifiers BSP Updated: 2021/11/30
The internal equivalent circuit of LM3 8-ON and the connection of the input circuit
are similar to the PNP differential amplification method. When using a single power supply, the output stage
consists of a SEPP output circuit, and the transistors are equivalent to PNP power tubes.
Because there is no internal feedback, the voltage amplification is fixed at 50 times (34dB).
At the same time, due to the high input level , a variable resistor is added to the input end to widen the
input level range. The power supply noise suppression of LM380N is relatively poor. , so
the AC filter electrical gap 1 is connected in series to the bias current lead (BP).
- Electromagnetic radiation monitor
- Homemade simple magnetic material tester
- Simple and practical motor short circuit tester
- Isolated 4-20mA instrument loop (RTD) circuit composed of RCV420
- Fire detector made with photodiode
- TC02 temperature measurement circuit
- A circuit for qualitatively testing capacitor leakage
- Temperature-frequency conversion circuit composed of CD4046
- High current, high power amplifier circuit
- Multimeter DC voltage measurement circuit
- Set timing circuit when power is on
- Analysis of rectifier circuit types and principles
- Electronic anti-asthma circuit
- Farmland irrigation automatic control circuit a
- DC ammeter
- Frequency modulator composed of NE566
- Simple AGC circuit in transistor radio
- Amplitude modulation circuit composed of MC1496
- Inductive feedback oscillator circuit
- Sawtooth wave generator circuit (1)
