Programmable amplifier with gain from 10 to 90dB selectable in 10dB increments
Source: InternetPublisher:spectrum Keywords: Programmable amplifier BSP AI Updated: 2020/12/27
Although the basic circuit of the Zhi amplifier is a non-phase AC amplifier, there are no
special changes. However, in order to select the correct amplification factor, the circuit uses
a resistance value of 9k0. that is not available in the Chou series resistors. OP37 was selected as the input amplifier Ai
(even if the amplification factor is large, the deterioration of the characteristics is very small, and there is no phase compensation
). In order to remove the broadband noise in the power supply line, the circuit is added with
'', g5 and chu5, Filter composed of c4. Although general OP amplifiers can be used for Ai ~As
, the conversion speed should be above 10 V/"s.
In order not to increase the DC offset voltage, 1011F capacitors are used in the backup amplifiers
, so that the win-current amplification factor is 10
- Balcony intelligent invisible anti-theft net
- Temperature Range Monitoring System
- DIY Multimeter High Frequency Signal Probe
- A highly sensitive human proximity detector
- Bat sound detection circuit
- Simple and easy to make zero degree detector
- How to create a simple oscilloscope using the Basys3 board
- direct coupled amplifier circuit
- Phase sequence indicator circuit diagram
- Multimeter DC voltage measurement circuit
- Set timing circuit when power is on
- Physiotherapy ventilator circuit
- Agricultural small tractor lighting circuit
- Wien bridge oscillator circuit
- Broadband high frequency power amplifier circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- common emitter amplifier circuit
- Fruit and vegetable greenhouse humidity control circuit
- New battery charging integrated circuit AIC1761/1766 circuit
- Macro JSYZ5-AI gas water heater circuit diagram
