The 5V power supply uses the LM2995 converter circuit
Source: InternetPublisher:失踪的猫 Keywords: power supply converter Updated: 2020/03/07
It is often necessary to supply low voltage 220V for power consumption. You could use an external adapter - but it's bad and reduces the size of the device and requires a power source located within the device.
This 5V power supply uses the LM2995 converter circuit and can be directly connected to 220V. To do this, AC is converted into DC voltage through diode bridge VD1 and then reduced to 40V. Above 40 V, we should not use it, since the maximum input voltage of LM2995 cannot exceed 45V.
Transistors T1 and T2 form a pulsating pressure amplitude dependent on Zener diode D1 of up to 40V. This pulsating voltage is smoothed by capacitor C1, which is slightly smoothed. The second is the on-chip downconverter output voltage stability, define the application chip: LM 2575-5 5V, which will be equal. Standard chip bundle of Schottky diodes D2, L1, C2 and C3.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- 220V Remote Load Monitor
- Recommended circuits for different power on times of LM4911
- Transformerless AC-DC constant current LED driver circuit
- Simple and practical LED lamp driving circuit
- A small and easy-to-make fast charger
- Design of electric vehicle charger
- Car Audio Power Supply
- Homemade Electric Bike Fast Charger
- Homemade home inverter circuit diagram
- Minimize noise and ripple using low-noise buck converters
- What are the three changes in power distribution structure?
- What determines the input power of a power supply?
- How many power supply methods are there for Arduino? What is the power circuit like?
- How to ensure that the power supply works for a long time—PA power analyzer
- Causes of inductor whistling in DC/DC circuits and related solutions
- Smart lock power supply method
- Power transformer use
- A stepper motor and its driving principle circuit diagram
- Medical infusion alarm circuit
