Internal structure and working principle diagram of HL402
Source: InternetPublisher:武林萌主 Keywords: gate comparator transistor Updated: 2021/06/05
Working Principle The HL402 principle block diagram is shown in Figure 12-47. In the figure, VL is
an optocoupler with electrostatic shielding, which is used to isolate the input signal. Because it
has electrostatic shielding, the HL402's ability to resist common-mode interference is significantly improved. V in the picture.
is a pulse amplifier, transistors V3, V. To realize driving pulse power amplification, V; is a reduction
gate voltage comparator . Under normal circumstances, since the IGBT collector voltage VCE input by pin 9
is not higher than the reference voltage V REF of V;, V; does not flip, and the transistor V; does not conduct pass, so
the drive pulse signal input from pins 17 and 16 is not blocked after being shaped by V, and the drive pulse is
passed through V,, V. After amplification, it is provided to the driven IGBT to drive the IGBT to turn on or off.
Once the driven IGBT is desaturated, the collector voltage sampling signal
VCE input by pin 9 is higher than V. The reference voltage V...comparator V. flipped, the output is high, making the transistor
V. When it is turned on, the voltage regulator tube VDz will drive the output gate voltage Vfi. Reduce to
10V. At this time, the soft-off timer v is reducing the gate voltage comparator V. After the flip reaches the set
time, the positive voltage is output to turn on the transistor V, and the gate voltage is softly turned off to reduce the gate -
emitter threshold voltage
of the 1GBT , providing a negative
driving voltage to the driven IGBI . Ensure that the driven IGBT is turned off reliably.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- A simple magnetic switch circuit sharing
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Design and production of wireless multi-location control switch circuit
- Infrared blocking alarm device
- Ultra-short wave item left behind reminder alarm
- Precious home appliance anti-theft alarm
- Homemade anti-theft watchdog
- Simple disconnection burglar alarm
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Paper tension control circuit
- Car window control circuit
- Infrared voice control circuit
- AM radio automatic search and trigger circuit
- Photoelectric output control circuit
- Intelligent iron control circuit
- Electric heater temperature detection control circuit
- Forward and reverse control circuit of micro DC motor a
