Here, SG3524 is only used as a pulse width modulator. The error amplifier
is connected in the form of a follower. As shown in Figure 10-7. The ACR output is connected to pin 2 as the PWM input
control signal. V. Connect in parallel with VB to obtain single-ended output mode. When S, is closed, the output PWM pulse is turned off
to stop the motor.
Obviously, this application method is also suitable for the control of DC motors and brushless current motors
. Since the switched reluctance motor winding current is only in one direction, it
is more suitable and simpler to use a switching power supply PWM control integrated circuit.
- A simple door handle touch alarm circuit
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- A small improvement to the temperature and water level indicator alarm
- Motor automatic cycle control circuit
- Using P110C to control 6 DC motors simultaneously
- IGBT modules block overcurrent by controlling the gate
- Light-controlled circuit design and analysis
- An experimental model of an infrared radio alarm
- Ultra-short wave item left behind reminder alarm
- Simple disconnection burglar alarm
- electromagnetic field sensor
- Excellent performance household inverter power supply circuit
- Electronic thermometer circuit
- Bone hyperplasia treatment circuit
- Pulse therapy circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Differential Amplifier Circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Color display circuit
- Guest arrival signal recognition circuit
